A couple requests
guys2
I have one issue and a request. I can't get the 5Ghz to work properly after installing you build. It doesn't seem to do the DNS. I can log in to the router but can't get to internet. The second is on traffic monitoring by ip. Or if you can tell me how to get it to work using scripts etc.
Guy
Guy
5 GHz issue: unrelated to my firmware, I'm not changing anything from the original firmware in this area. Make sure you use the correct security mode, and that you didn't enable the MAC Address filter on the Wireless section. Also try updating your wireless drivers, and make sure you have everything set to automatic. Also, see if you are actually obtaining an IP lease from the router.
Traffic by IP: no idea. The closest thing I ever found was wrtbwmon - see the Wiki entry for pointers.
