Hi
Been a lurker for a while and read lots of articles but now decided I need to get a grip of this matter. The more I read about Orbi things ie backhaul etc the more confused I become.
I have had an Orbi system for some years now but am not convinced I am utilising it to its fullest. I have a RBR50 router, RBS50 satellite x2, RBS40 satellite and a RBW30 satellite all connected. Router and two satellites,
RBS50 and RBS40, on ground floor other two satellites upstairs.
I started off with just the RBR50 and the two RBS50s but was never over confident they were doing the job, hence the purchase 2nd hand of the others. Some areas upstairs have very poor signal strength if any at all.
Now I have read that one should not have more than two satellites, others say you can have up to four even on wifi 5. I have contemplated getting rid of the Orbis and installing a good single router then using, better antennae, extenders and or
an amplifier but wonder if I digging myself into a hole. The system is in a big old rambling property, 16th century in UK with some thick walls. Unfortunately, as is often the case, the phone line enters
the property in one corner so not ideally placed. Mind you I would have thought with a mesh system this is not as crucial as if using a normal router. I have moved the satellites around but seems to not make much difference. I am not after
blistering speeds, only used for normal web access and odd YouTube video. I would just blike to have a decent signal in all rooms.
So what I am trying to get around to is should I stick with the Orbi setup? or go down a different route. I even comtemplated using an outdoor directional antenna, poe sort of thing, to do the upstaris with a standard wireless router doing downstairs.
I could if need run an ethernet cable to somewhere approximating more to the centre of the house but again do I need to if using a mesh setup? I am out in the country so the use of an amplifier would not upset anybody.
As you can see I have not got a clue and any help will greatfully received.
Regards
DAVE
Regards
DAVE
