AC3200 Disconnect Issues
Davahad
For the last 2 days been having wireless disconnect issues and cannot figure it out. Prior to this was not having any disconnect issues. Below is a snippet of the logs from 2 days and attached is the log file for the last 2 days.
Does the log file give any indication as to what the issue could be? Thanks in advance for any help.
Apr 24 19:21:45 rc_service: ntp 405:notify_rc restart_diskmon
Apr 24 19:21:45 disk_monitor: Finish
Apr 24 19:21:46 disk monitor: be idle
Apr 24 19:21:49 vpnserver1[553]: OpenVPN 2.3.2 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [eurephia] [MH] [IPv6] built on Jan 4 2019
Apr 24 19:21:49 vpnserver1[553]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
Apr 24 19:21:49 vpnserver1[553]: Diffie-Hellman initialized with 2048 bit key
Apr 24 19:21:49 vpnserver1[553]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Apr 24 19:21:49 vpnserver1[553]: TUN/TAP device tun21 opened
Apr 24 19:21:49 vpnserver1[553]: TUN/TAP TX queue length set to 100
Apr 24 19:21:49 vpnserver1[553]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Apr 24 19:21:49 vpnserver1[553]: /sbin/ifconfig tun21 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Apr 24 19:21:49 vpnserver1[553]: /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
Apr 24 19:21:49 vpnserver1[557]: UDPv4 link local (bound): [undef]
Apr 24 19:21:49 vpnserver1[557]: UDPv4 link remote: [undef]
Apr 24 19:21:49 vpnserver1[557]: MULTI: multi_init called, r=256 v=256
Apr 24 19:21:49 vpnserver1[557]: IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
Apr 24 19:21:49 vpnserver1[557]: Initialization Sequence Completed
Apr 24 19:22:06 kernel: SHN Release Version: 2.0.1 3529123_patch
Apr 24 19:22:06 kernel: UDB Core Version: 0.2.14 r3529123
Apr 24 19:22:06 kernel: sizeof forward pkt param = 192
Apr 24 19:22:07 BWDPI: fun bitmap = 7f
Apr 24 19:22:09 rc_service: udhcpc 380:notify_rc start_firewall
Apr 24 19:22:10 dhcp client: bound 73.241.47.3 via 73.241.46.1 during 217386 seconds.
Apr 24 19:22:10 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Apr 24 19:22:27 crond[278]: time disparity of 511037 minutes detected
Apr 24 19:23:35 hour monitor: ntp sync fail, will retry after 120 sec
Apr 24 19:36:41 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 19:36:41 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 19:51:42 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 19:51:42 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 20:00:46 disk_monitor: Got SIGALRM...
Apr 24 20:06:32 rc_service: httpd 280:notify_rc start_webs_update
Apr 24 20:06:43 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 20:06:43 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 20:21:20 acsd: COEX: downgraded chanspec 0x1806 to 0x1004: channel 1 used by exiting BSSs
Apr 24 20:21:20 acsd: selected channel spec: 0x1004 (4)
Apr 24 20:21:20 acsd: Adjusted channel spec: 0x1004 (4)
Apr 24 20:21:20 acsd: selected DFS-exit channel spec: 0x1004 (4)
Apr 24 20:21:21 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 20:21:21 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 20:21:21 acsd: selected DFS-exit channel spec: 0xe02a (36/80)
Apr 24 20:21:26 acsd: eth2: NONACSD channel switching to channel spec: 0x1004 (4)
Apr 24 20:21:26 acsd: eth1: NONACSD channel switching to channel spec: 0xe02a (36/80)
Apr 24 20:33:39 rc_service: httpd 280:notify_rc start_webs_update
Apr 24 20:36:27 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 20:36:27 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 20:51:30 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 20:51:30 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 21:06:31 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 21:06:31 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 21:21:33 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 21:21:33 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 21:36:34 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 21:36:34 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 21:51:35 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 21:51:35 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 22:06:37 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 22:06:37 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 22:21:38 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 22:21:38 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 22:36:41 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 22:36:41 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 22:51:42 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 22:51:42 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 23:00:46 disk_monitor: Got SIGALRM...
Apr 24 23:06:44 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 23:06:44 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 23:21:45 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 23:21:45 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 23:36:46 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 23:36:46 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 24 23:51:48 acsd: selected channel spec: 0xe02a (36/80)
Apr 24 23:51:48 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 00:06:49 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 00:06:49 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 00:21:51 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 00:21:51 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 00:36:52 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 00:36:52 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 00:51:54 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 00:51:54 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 01:06:55 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 01:06:55 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 01:21:56 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 01:21:56 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 01:36:59 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 01:36:59 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 01:52:00 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 01:52:00 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 02:00:31 vpnserver1[557]: 185.200.118.83:34621 TLS: Initial packet from [AF_INET]185.200.118.83:34621 (via [AF_INET]73.241.47.3%eth0), sid=12121212 12121212
Apr 25 02:01:31 vpnserver1[557]: 185.200.118.83:34621 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Apr 25 02:01:31 vpnserver1[557]: 185.200.118.83:34621 TLS Error: TLS handshake failed
Apr 25 02:01:31 vpnserver1[557]: 185.200.118.83:34621 SIGUSR1[soft,tls-error] received, client-instance restarting
Apr 25 02:07:02 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 02:07:02 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 02:22:03 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 02:22:03 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 02:37:05 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 02:37:05 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 02:52:06 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 02:52:06 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 03:07:07 acsd: selected channel spec: 0xe02a (36/80)
Apr 25 03:07:07 acsd: Adjusted channel spec: 0xe02a (36/80)
Apr 25 03:22:09 acsd: selected channel spec: 0xe02a (36/80)
