After upgrade to. 47 i can't revert back to. 43
lostindark
Hi guys today i try to upgrade to. 47 but after that try to revert back. 43 - flash process goes o.k. but when i restore my backup setting file everything looks mix&match. I've Try to clear nvram try to restore factory settings and than again to restore nothings help..
Now i flash. 38 with restore settings from. 38 and it works but when i try to revert back to. 43 nothing? Can you help?
You cannot use old backup settings file on new FW, you should clean nvram and reset to defaut and then config it by hand.
Thanks, i know that, I've clear nvram, do factory setting restore after flashing .43 but when i try to apply backup settings from the same firmware it looks mixed with settings from factory restore. 2.4 GHz network has rename but 5GHz still standing Asus 5G,the same situation i have with other settings ones of them are set other still stay by default.
Sent from my LG-D802 using Tapatalk
Try entering the following commands via SSH/telnet
mtd-erase -d jffs2
mtd-erase -d nvram
reboot
Then do a factory reset.
You will lose anything in the jffs partition, so back up any scripts/config files first.
