AdGuardHome AGH not working on new firmware 3006
I get this info in return
That’s not the full expected download size.
How about:
curl --stderr /tmp/curlerrors.txt -D /tmp/headers.out --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -L https://api.github.com/repos/AdguardTeam/AdGuardHome/releases
HTTP/1.1 403 rate limit exceeded
Date: Wed, 09 Jul 2025 19:11:00 GMT
Server: Varnish
Strict-Transport-Security: max-age=31536000; includeSubdomains; preload
X-Content-Type-Options: nosniff
X-Frame-Options: deny
X-XSS-Protection: 1; mode=block
Content-Security-Policy: default-src 'none'; style-src 'unsafe-inline'
Access-Control-Allow-Origin: *
Access-Control-Expose-Headers: ETag, Link, Location, Retry-After, X-GitHub-OTP, X-RateLimit-Limit, X-RateLimit-Remaining, X-RateLimit-Reset, X-RateLimit-Used, X-RateLimit-Resource, X-OAuth-Scopes, X-Accepted-OAuth-Scopes, X-Poll-Interval, X-GitHub-Media-Type, Deprecation, Sunset
Content-Type: application/json; charset=utf-8
Referrer-Policy: origin-when-cross-origin, strict-origin-when-cross-origin
X-GitHub-Media-Type: github.v3; format=json
X-RateLimit-Limit: 60
X-RateLimit-Remaining: 0
X-RateLimit-Reset: 1752090548
X-RateLimit-Resource: core
X-RateLimit-Used: 60
Content-Length: 278
X-GitHub-Request-Id: BECE:21F96E:25878E7:266428E:686EBEC3
So it means one way or another you already used 60 queries in an hour, and can try again in about 25 minutes based on the reset time in epoch seconds.
Thank you, I will do so. Can you explain how I have used this 60 queries?
No, that’s the big mystery. Unless there’s another application on your LAN also querying the github API, and appearing to come from your WAN IP.
The one shared by SomeWhereOverTheRainBow
I tried every 15-20 minutes and was lucky after 3 or 4 attempts.
I was able to run this above and everything seems to be fine now. It did say I was on 1.8.1 when I ran the above command. Not sure why as it seemed to update some files.
If he is on CGNAT and other people have the same public facing IP address it can cause this issue. And it doesnt matter what part of github api they are trying to use.
The IP he reported in the ratelimit post #62 (now redacted) matched his actual WAN IP on the router, so it wouldn’t be a CGNAT scenario.
I was manage to get it done, after waiting for 1 hour
I just released an update. Part of the problem for the ratelimiting could be caused by AMTM's checking method. I have no clue how many times AMTM is trying to access AGH version. @dave14305 found an issue inside the AGH module file. On another note, I have just significantly reduced the amount of times the installer script will check for versions from the Github API. My next step will be to check out access tokens.
Release v1.8.2
changelog
There could be clues in the /jffs/curllst files.
grep -A1 curl.*api\.github\.com /jffs/curllst*
So I have reduced the amount of the .json I pull by adding "?per_page=3" to the end of the url.
curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time $((3 * 5)) --retry-connrefused -sL "${LATEST_URL}?per_page=3" -o "${API_FILE}"
Now I download it to a temporary file, and only parse the versions from the temporary file.
@Stephen Harrington @Apul @bluzfanmr1 @saison2023 @jsbeddow
Sorry to ping all of you, but you have been providing good feed back on this ongoing issue. I have just released v1.8.2. When you have the time, please let me know how it goes upgrading. Do not try it from AMTM menu. That is a different issue that must be resolved before I would recommend using the "ag" command. Instead, use the terminal command line with the installation command I have provided.
curl -L -s -k -O https://raw.githubusercontent.com/jumpsmm7/Asuswrt-Merlin-AdGuardHome-Installer/master/installer && sh installer
If you experience any problems performing the upgrade, please do as @dave14305 has mentioned. run grep -A1 curl.*api\.github\.com /jffs/curllst* in the terminal command line. Report the output back here. Please redact any IP addresses.
