AdGuardHome AGH not working on new firmware 3006
Report the output back here. Please redact any IP addresses.
@SomeWhereOverTheRainBow my upgrade failed, output as below, sorry trying to do it on an iPad remotely but hope info helps...
admin@AsusRouter:/tmp/home/root# curl -L -s -k -O https://raw.githubusercontent.com/jumpsmm7/Asuswrt-Merlin-AdGuardHome-Installer/master/installer && sh installer
One or more critical variables could not be set in a timely manner.
It is possible we have hit the github api ratelimit, or your internet maybe down.
Please check your internet connection, or try again in an hour.
The installer script will now exit.
admin@AsusRouter:/tmp/home/root# grep -A1 curl.*api\.github\.com /jffs/curllst*
/jffs/curllst:(2944)/usr/sbin/curl -fsNL --connect-timeout 10 --retry 3 --max-time 12 https://api.github.com/repos/AdguardTeam/AdGuardHome/releases/latest
/jffs/curllst-(2943)/bin/sh /usr/sbin/amtm
/jffs/curllst:(6049)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_6049.json
/jffs/curllst-(4176113)/bin/sh /opt/etc/AdGuardHome/installer
/jffs/curllst:(38067)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_38067.json
/jffs/curllst-(4175322)sh installer
/jffs/curllst:(41082)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_41082.json
/jffs/curllst:(44538)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_44538.json
/jffs/curllst.1:(4177871)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_4177871.json
/jffs/curllst.1-(4176113)/bin/sh /opt/etc/AdGuardHome/installer master
I think I have fixed it. It was a simple logic change.
You added a compressed parameter that isn’t supported using built-in curl.
# curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time $((3 * 5)) --retry-connrefused -sL --compressed https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/api.json
curl: option --compressed: the installed libcurl version doesn't support this
curl: try 'curl --help' for more information
nice catch. fixed.
AMTM still fails
 Enter amtm option  ag
One or more critical variables could not be set in a timely manner./nPlease check your internet connection, or try again later./nThe installer script will now exit./n
AdGuardHome 1.8.2 -> MD5 upd
When I try to update, I get:
Thanks for all your work on this! :) @SomeWhereOverTheRainBow
Make sure you are putting this into the commandline.
curl -L -s -k -O https://raw.githubusercontent.com/jumpsmm7/Asuswrt-Merlin-AdGuardHome-Installer/master/installer && sh installer only install using this command
@darkony no "ag" method, until you have upgraded using the commandline method.
@RT-AX86U-CC08:/tmp/home/root# curl -L -s -k -O https://raw.githubusercontent.com/jumpsmm7/Asuswrt-Merlin-AdGuardHome-Installer/master/installe
r && sh installer
@darkony @tripmyflip what output do you get for this command grep -A1 curl.*api\.github\.com /jffs/curllst*
/jffs/curllst:(557448)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_557448.json
/jffs/curllst-(5559)/bin/sh /opt/etc/AdGuardHome/installer master
/jffs/curllst:(561826)/usr/sbin/curl -fsNL --connect-timeout 10 --retry 3 --max-time 12 https://api.github.com/repos/AdguardTeam/AdGuardHome/releases/latest
/jffs/curllst-(561825)/bin/sh /usr/sbin/amtm
/jffs/curllst.1:(532215)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_532215.json
/jffs/curllst.1-(424978)/bin/sh /opt/etc/AdGuardHome/installer
/jffs/curllst.1:(533356)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_533356.json
/jffs/curllst.1:(534550)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_534550.json
/jffs/curllst.1:(535592)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_535592.json
/jffs/curllst.1:(537047)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_537047.json
/jffs/curllst.1:(538124)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_538124.json
/jffs/curllst.1:(540181)/usr/sbin/curl -fsNL --connect-timeout 10 --retry 3 --max-time 12 https://api.github.com/repos/AdguardTeam/AdGuardHome/releases/latest
/jffs/curllst.1-(540180)/bin/sh /usr/sbin/amtm
/jffs/curllst.1:(541667)/usr/sbin/curl -fsNL --connect-timeout 10 --retry 3 --max-time 12 https://api.github.com/repos/AdguardTeam/AdGuardHome/releases/latest
/jffs/curllst.1-(541666)/bin/sh /usr/sbin/amtm
/jffs/curllst.1:(542313)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_542313.json
/jffs/curllst.1:(543570)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_543570.json
/jffs/curllst.1:(544678)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_544678.json
/jffs/curllst.1:(557448)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases?per_page=3 -o /tmp/AGH_GIT_API_557448.json
/jffs/curllst.1-(5559)sh installer
Yea i am not officially sure what creates the error messages for amtm. You could try running "uu" to force update all of amtm auxillary files (including the addon files) which are managed and for the most part maintained by thelonelycoder.
Force updated Amtm, also updated the AG script to 1.8.2 (and automatically beta to .72). Same error is displayed in Amtm regarding the beta update status.
Not a big issue, AG itself is working fine, that's the most important.
Thanks for your hard work and the support!
Below:
@RT-AX86U-CC08:/tmp/home/root# grep -A1 curl.*api\.github\.com /jffs/curllst*
/jffs/curllst:(1)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases
/jffs/curllst-(0)/sbin/init
/jffs/curllst.1:(1)curl --retry 3 --connect-timeout 3 --retry-delay 1 --max-time 15 --retry-connrefused -sL https://api.github.com/repos/AdguardTeam/AdGuardHome/releases
/jffs/curllst.1-(0)/sbin/init
I ran the above command and all was well. AMTM had shown there was an update to 1.8.2 but I didn't run it via that method as requested. After the successful update via the cli, amtm correctly showed 1.8.2 as the version. Thanks for the work on this, it's greatly appreciated.
Same here, ran the command that was provided to update and now I am at 1.8.2
EDIT: I faced some error message about rate limit after the update script and in AMTM when I looked for any update but everything went back to normal after few minutes.
