AiCloud, admin webui and custom certificates
Iwakan
First of all sorry if this possible bug is already identified. I was searching and didn't find info about it.
If you want to change admin webui self signed default certificate there's no need to follow steps like run different commands thru ssh, is as easy as enable AiCloud SmartAccess, login into it and in configuration -> certs, upload your custom certificate. After this, your routers webui will also use this certificate. The problem is that if router is rebooted, admin webui custom cert works flawlessly but AiCloud not (still using default self signed).
To workaround this I need to disable AiCloud Smart Access, reboot the router and then enable AiCloud Smart Access. After that, admin webui and AiCloud works perfectly with custom cert. Maybe this is easy to fix or I'm doing something wrong (I tried to restart httpd and AiCloud service after router startup without success ).
My current environment is: AC68u with Merlin 58 final.
