Aimesh node information
StefanoN
Hello
I use an rt-ac68u and a dsl-ac68u with stock firmware as aimesh nodes. Is it possible to use their ethernet ports too? I tried to connect a PC linux to one of the ports but since I connected it I have had problems with the wifi (some IOT devices connected and disconnected).
The problem was solved by disconnecting the PC Linux + reboot of nodes.
I use the ports on all my nodes with no problem.
Hello
As stated above, wired ports on nodes work fine. At least with the RT-AC68U. I don't have any knowledge of the DSL version.
Are you sure your PC is using DHCP? Make sure it doesn't use a fixed IP or you might had address conflicts.
thanks for the replies. The ip addresses are different, what I noticed is that the problems have been born since I installed the 384.14 on the rt-ac86u router. Now I am testing version 384.15 and at the moment I am not experiencing problems or need to restart the nodes.
