All connections over Ethernet won't work but WiFi works fine
Tennessee Jed
So here is my story. A couple days ago I awoke to having no internet access over any devices connected through Ethernet or Wifi. My first thought was it was just a fluke and to power cycle my router and modem. After doing so I still got nothing. Called up my ISP thinking that the internet might be down due to a winter storm we had that night. They said that it wasn't. They sent signals to my modem and everything appeared to be working properly.
My equipment then:
Arris SB6141
Asus RT-AC3200
So I decided to make a run to Best Buy (not my first choice but convenient) to pick up a new cable modem. Purchased a Arris SB6190. Got it home, called up ISP (Spectrum) and had them provision it. Everything went smooth. Well now I was getting internet but only over WiFi. So now I'm thinking that my router bit the dust. Took another trip to Best Buy and purchased a Linksys EA9500 router. Got home, hooked it all up, same exact thing. Wifi works but everything connected through Ethernet has no connection.
Here is my IPConfig:
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-7HQ2CMF
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Killer E2400 Gigabit Ethernet Controller
Physical Address. . . . . . . . . : 70-85-C2-0A-10-CC
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::c4c8:3703:cba:b6%11(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.0.182(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 275809730
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-76-DC-58-70-85-C2-0A-10-CC
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Local Area Connection* 11:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 76-19-F8-10-77-74
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : neo.rr.com
Description . . . . . . . . . . . : Realtek 8812AE Wireless LAN 802.11ac PCI-E NIC
Physical Address. . . . . . . . . : 74-19-F8-10-77-74
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
I've been pulling my hair out over this and I can't seem to figure it out. I've tried netsh winsock reset and all the other release and renew commands to no avail. I really hope that someone can help me out. I know that the 169.254 indicates that my router isn't handing out the IP so I checked and DHCP is definitely enabled. I'm at my wits end here so any help is MUCH appreciated.
T Home Network Ethernet Wiring Routers 10
