Any reason an RP-AX58 would be showing up at an RP-AX56?
cobolsam
Today I received a used RP-AX58 I ordered from eBay. The packaging and stickers on the device both indicate it is an RP-AX58, but when I connected it to my AiMesh network, it shows up as an RP-AX56. Have I been scammed or could there be another reason for this happening? Any tips on how I can investigate further to confirm the device model?
Thanks in advanced.
Via the GUI, try flashing the firmware for the model you believe you paid for.
Where is it indicating RT-AX56?
Screenshots may help here.
I'm seeing the RP-AX56 on the web interface and on the android app. Note, I already had one RP-AX58, the AX56 is the new device.
Flashing RP-AX58 firmware fails. I think I've been scammed. Thanks for the suggestion. I'm going to initiate a return.
