Anyone with luck on AX88U using WPA 2 Enterprise security
marcwkh
I have AX88U running 384.12 beta (but this problem also occurs on 384.11, therefore it is not the problem of beta firmware). I have tried to set up WPA 2 Enterprise mode using my QNAP 253A as the radius server.
The set up would be initially stable, however when I tried to connect the clients the next day (let say back home from work.......) the clients would keep on disassociate and reassociate in around every 2 minutes.
This is annoying, as disconnects while streaming video on phone mean using precious mobile data quota.
The AX88U would maintain stable connects for many hours if security mode is WPA 2 Personal, therefore I assume it is not faulty hardware in AX88U.
Anyone with luck with WPA2 Enterprise? What are your tricks in setting it up?
