[RT-AC66U] WPA 2 Enterprise + OPENVPN + RADIUS + NO WIFI
Jamyz
Hi Everybody!!!
I use a RT-AC87U (VPN SERVER) and the RT-AC66U (VPN CLIENT) for the network(Works Great).
On VPN SERVER side i have a NAS With an RADIUS Server.
All the client from VPN CLIENT side use WPA 2 Enterprise to connect with the wifi (The Radius Server is on VPN SERVER side).
All works great.
But every time the router RT-AC66U reboot at scheduling 6:00AM, no more request to the radius server.
I need to put the wifi settings on OPEN SYSTEM and back to WPA2 Enterprise to the router request the Radius Server.
Some Logs:
Jun 20 06:01:15 openvpn[731]: [RT-AC87U] Inactivity timeout (--ping-restart), restarting
Jun 20 06:01:15 openvpn[731]: SIGUSR1[soft,ping-restart] received, process restarting
Jun 20 06:01:15 openvpn[731]: Restart pause, 5 second(s)
Jun 20 06:01:20 openvpn[731]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jun 20 06:01:20 openvpn[731]: TCP/UDP: Preserving recently used remote address: [AF_INET]111.222.333.444:1194
Jun 20 06:01:20 openvpn[731]: Socket Buffers: R=[118784->118784] S=[118784->118784]
Jun 20 06:01:20 openvpn[731]: UDP link local: (not bound)
Jun 20 06:01:20 openvpn[731]: UDP link remote: [AF_INET]111.222.333.444:1194
Jun 20 06:02:21 openvpn[731]: [UNDEF] Inactivity timeout (--ping-restart), restarting
Jun 20 06:02:21 openvpn[731]: SIGUSR1[soft,ping-restart] received, process restarting
Jun 20 06:02:21 openvpn[731]: Restart pause, 5 second(s)
Jun 20 06:02:26 openvpn[731]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jun 20 06:02:26 openvpn[731]: TCP/UDP: Preserving recently used remote address: [AF_INET]111.222.333.444:1194
Jun 20 06:02:26 openvpn[731]: Socket Buffers: R=[118784->118784] S=[118784->118784]
Jun 20 06:02:26 openvpn[731]: UDP link local: (not bound)
Jun 20 06:02:26 openvpn[731]: UDP link remote: [AF_INET]111.222.333.444:1194
Jun 20 06:03:26 openvpn[731]: [UNDEF] Inactivity timeout (--ping-restart), restarting
Jun 20 06:03:26 openvpn[731]: SIGUSR1[soft,ping-restart] received, process restarting
Jun 20 06:03:26 openvpn[731]: Restart pause, 5 second(s)
Jun 20 06:03:31 openvpn[731]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jun 20 06:03:31 openvpn[731]: TCP/UDP: Preserving recently used remote address: [AF_INET]111.222.333.444:1194
Jun 20 06:03:31 openvpn[731]: Socket Buffers: R=[118784->118784] S=[118784->118784]
Jun 20 06:03:31 openvpn[731]: UDP link local: (not bound)
Jun 20 06:03:31 openvpn[731]: UDP link remote: [AF_INET]111.222.333.444:1194
Jun 20 06:03:31 openvpn[731]: TLS: Initial packet from [AF_INET]111.222.333.444:1194, sid=d22e180a 97baa065
Jun 20 06:03:32 openvpn[731]: VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC87U, emailAddress=me@myhost.mydomain
Jun 20 06:03:32 openvpn[731]: VERIFY KU OK
Jun 20 06:03:32 openvpn[731]: Validating certificate extended key usage
Jun 20 06:03:32 openvpn[731]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Jun 20 06:03:32 openvpn[731]: VERIFY EKU OK
Jun 20 06:03:32 openvpn[731]: VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC87U, emailAddress=me@myhost.mydomain
Jun 20 06:03:32 openvpn[731]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 1024 bit RSA
Jun 20 06:03:32 openvpn[731]: [RT-AC87U] Peer Connection Initiated with [AF_INET]111.222.333.444:1194
Jun 20 06:03:33 openvpn[731]: SENT CONTROL [RT-AC87U]: 'PUSH_REQUEST' (status=1)
Jun 20 06:03:33 openvpn[731]: PUSH: Received control message: 'PUSH_REPLY,route 192.168.1.0 255.255.255.0 vpn_gateway 500,route-gateway 10.8.0.1,topology subnet,ping 15,ping-restart 60,ifconfig 10.8.0.2 255.255.255.0,peer-id 0,cipher AES-128-GCM'
Jun 20 06:03:33 openvpn[731]: OPTIONS IMPORT: timers and/or timeouts modified
Jun 20 06:03:33 openvpn[731]: OPTIONS IMPORT: --ifconfig/up options modified
Jun 20 06:03:33 openvpn[731]: OPTIONS IMPORT: route options modified
Jun 20 06:03:33 openvpn[731]: OPTIONS IMPORT: route-related options modified
Jun 20 06:03:33 openvpn[731]: OPTIONS IMPORT: peer-id set
Jun 20 06:03:33 openvpn[731]: OPTIONS IMPORT: adjusting link_mtu to 1625
Jun 20 06:03:33 openvpn[731]: OPTIONS IMPORT: data channel crypto options modified
Jun 20 06:03:33 openvpn[731]: Data Channel: using negotiated cipher 'AES-128-GCM'
Jun 20 06:03:33 openvpn[731]: Data Channel Encrypt: Cipher 'AES-128-GCM' initialized with 128 bit key
Jun 20 06:03:33 openvpn[731]: Data Channel Decrypt: Cipher 'AES-128-GCM' initialized with 128 bit key
Jun 20 06:03:33 openvpn[731]: Preserving previous TUN/TAP instance: tun11
Jun 20 06:03:33 openvpn[731]: Initialization Sequence Completed
When i use open system and back to WPA2 Enterprise :
Jun 20 06:33:49 rc_service: httpds 290:notify_rc restart_wireless
Jun 20 06:33:51 kernel: br0: port 2(eth1) entering disabled state
Jun 20 06:33:51 kernel: device eth1 left promiscuous mode
Jun 20 06:33:51 kernel: br0: port 3(eth2) entering disabled state
Jun 20 06:33:51 kernel: device eth2 left promiscuous mode
Jun 20 06:33:55 kernel: wl_module_init: passivemode set to 0x0
Jun 20 06:33:55 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jun 20 06:33:55 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jun 20 06:33:55 kernel: device eth1 entered promiscuous mode
Jun 20 06:33:55 kernel: br0: port 2(eth1) entering listening state
Jun 20 06:33:55 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Jun 20 06:33:55 kernel: br0: port 2(eth1) entering learning state
Jun 20 06:33:55 kernel: br0: topology change detected, propagating
Jun 20 06:33:55 kernel: br0: port 2(eth1) entering forwarding state
Jun 20 06:33:55 kernel: device eth2 entered promiscuous mode
Jun 20 06:33:55 kernel: br0: port 3(eth2) entering listening state
Jun 20 06:33:55 kernel: br0: port 3(eth2) entering learning state
Jun 20 06:33:55 kernel: br0: port 3(eth2) entering forwarding state
Jun 20 06:34:03 dnsmasq-dhcp[289]: DHCPREQUEST(br0) 192.168.0.123 a4:51:6f:24:84:d8
Jun 20 06:34:03 dnsmasq-dhcp[289]: DHCPACK(br0) 192.168.0.123 a4:51:6f:24:84:d8 Windows-Phone
Jun 20 06:34:26 rc_service: httpds 290:notify_rc restart_wireless
Jun 20 06:34:28 kernel: br0: port 2(eth1) entering disabled state
Jun 20 06:34:28 kernel: device eth1 left promiscuous mode
Jun 20 06:34:28 kernel: br0: port 3(eth2) entering disabled state
Jun 20 06:34:28 kernel: device eth2 left promiscuous mode
Jun 20 06:34:31 kernel: wl_module_init: passivemode set to 0x0
Jun 20 06:34:32 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Jun 20 06:34:32 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.163.2002 (r382208)
Works because Windows Phone is connected
Any ideas ?
