Asus 86u (ExpressVpn) and Merlin 384.7.2
Make sure now that you have the right IP routed through the tunnel.
its set to yes
Are you able to share screenshots of your VPN configuration settings ? If yes, make sure to block your personal info first.
And make sure to clear your browser’s cache, then close it and then restart it again.
The policy rule for a device through the tunnel would look like this:
Have you tried policy rules strict?
Do you have any custom settings at the bottom of the client config?
From the setup page I linked to..
remote-cert-tls server
remote-random
nobind
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
ping-timer-rem
reneg-sec 0
# log /tmp/vpn.log
remote-random
nobind
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
ping-timer-rem
reneg-sec 0
# log /tmp/vpn.log
Sorry, I would start by removing all of the custom stuff above except for, remote-cert-tls server.
Do you have any other clients set up? 2 thru 5?
Is "Block routed clients if tunnel goes down" set to YES on any of them, running or not?
No one is using compression right now unless you are talking about lz4-v2
@DAVID LONG raised a great question above. Make sure you check that out.
If it is set to "no" and your laptop still doesn't have internet, there is something wrong with the laptop......right?
