ASUS AC3200 - advise
xKOLDx
Hi Everyone
looking a bit of advise, i have recently upgraded to an asus ac3200 but the wifi isn't the greatest, I'm considering sending it back and buying 2 routers (same brand and model) so i can put the second one upstairs as an AP as i cant mount a proper AP to the ceiling
the reason my wifi is struggling is because all the walls in my home are concrete
could someone advise on a decently priced router
Many thanks
No single router will be able to solve your issue - power output is limited by local regulations, so if a max output can't get through the concrete, you will have to go with multiple access points.
A pair of RT-AC68U or RT-AC66U_B1 would get the job done. You can also look into the various mesh solutions that are currently on the market.
Make sure they really are RT-AC66U_B1, not just RT-AC66U. That one is an older model, with a single core CPU.
The picture in your link is of the old model. No usb3 and it has removable antenna.
Routers arrived today they are the B1 version so i will set these up tonight when im home from work thank you for your suggestions
i have got the new routers installed and they are working perfectly, many thanks for the suggestion :)
