It's actually currently set to high because it really should only require a bitrate of 5-10 Mbps. The stream usually starts out 1080p then gradually degrades until it hits 240p and then stop playing to buffer for a few minutes. The whole point me fiddling around with these settings is that I believe the TV should be able to do 1080p Netflix consistently.Try adjusting the netflix streaming rate - login to Netflix on the PC, go to account settings, and you'll see the menu there - likely it's set to auto - set it to a limit rather than auto, and things will work better...
