Asus Ax89x connecting from outside via Wan.
Gribnik
Hello dear forum users. Please help me to solve the issue. The router has a static external IP, connected via OpenVPN to Nord VPN. I can't connect to the router from outside (Wan). When I disconnect from Nord VPN, the connection to the router works without problems.
How are you testing? What settings have you changed/added in Nord VPN?
Hello. Help me please solve the problem. There is a router Asus Ax89x revision b1. The router is connected to an Internet provider using the PPPoE protocol and has a dedicated static IP address. The router is connected to the Nord VPN service using the Open VPN protocol. I cannot remotely access my router when it is connected to the Nord VPN service. As soon as I disable the VPN connection in the router, then remote access to the router is possible. What do I need to do in order to remotely connect to the router without disconnecting it from the Nord VPN service? Thank you.
