If I run the GT-BE98 Pro as router the GT-AXE16000 5 GHz-2 is dead. I assume 6 GHz-2 would be dead if I tried the opposite. It's been a long time since I've had one AiMesh in the house and I really wanted it back. There's nothing I can set on the main SSID as noted somewhere except WPA security, so I set it as WPA3 since I know 6 GHz/6 GHz-1 and 6 GHz-2 only run on WPA3 or Open... Which leaves out a lowly iPad Air 2 to connect to other WiFi in the household.This router is inexpensive and runs the new 3006 UI, but the hardware inside is based on ~2016 BCM4906. It has ARMv8 cores CPU with AES and 512MB RAM, performance equivalent to RT-AC86U from 2017. Your routers used as APs perhaps have better hardware.
Hey, I got the beautiful "new" UI that the GT-BE19000Ai has, for pennies on the dollar...
