ASUS RT-AC3100 Firmware version 3.0.0.4.384.81116
SwampKracker
Security fix
- Fixed a DDoS vulnerability. Thanks for Altin Thartori's contribution.
Bug fix
- Fixed web control interface login problem.
- Fixed Network map clist list issues.
- Fixed block internet access problem when clients connected to AiMesh node
- Fixed Samba server compatibility issue.
- Fixed OpenVPN related bugs.
- Fixed schedule reboot bugs.
- Improved AiMesh compatibility.
- Improved system stability.
- Fixed User interface related bugs.
Please unzip the firmware file first then check the MD5 code.
MD5: 037f4b026f9afa21baa356ef97ef4b85
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AC3100/FW_RT_AC3100_300438481116.zip
I applied this update a couple days ago and haven't noticed any issues on either of my AC3100's. It's also available by using the GUI (check for update) if you don't want to manually DL it (or at least ti was when I updated).
