Asus RT-AC66U (not B1) v3.0.0.4.382.50470
o-l-a-v
Changelog
https://www.asus.com/Networking/RTAC66U/HelpDesk_BIOS/
ASUS RT-AC66U Firmware version 3.0.0.4.382.50470
- Support multi-language (UTF-8) network name
(Windows XP and Windows 7 do not support UTF-8 format SSID. These two OS may see gibberish if using multi-language SSID.)
- Improved system stability.
- Improved compatibility for IntelⓇ CentrinoⓇ 802.11ac card.
- Fixed XSS vulnerability. Thanks to Yonghui Han of Fortinet's FortiGuard Labs.
- Fixed CVE-2018-8877, CVE-2018-8878, CVE-2018-8879
- Fixed plain text password vulnerability in lighttpd.
- Modified Quick Internet Setup wizard process.
- Main SSID and guest network can hide independently.
- Fixed AiCloud login issue.
Please unzip the firmware file first then check the MD5 code.
MD5: 06bce3dbe93c5db13f2d8ecea3b912fc
Download
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC66U/FW_RT_AC66U_300438250470.ZIP
File name: FW_RT_AC66U_300438250470.ZIP
Could be coincidence but since installing 3.0.0.4.382_50470 a few days ago my RT-A66U wifi lost connectivity a few times. Anybody else?
**UPDATED - Clarified that the A66U wifi was stalled out but the router itself did not reboot based on the log reading**
Could be coincidence but since installing 3.0.0.4.382_50470 a few days ago my RT-A66U has rebooted on its own a few times. Anybody else?
Considering it's a major upgrade from 380 to 382, I would recommend doing a factory default reset, and manually reconfiguring everything. That might help with those types of random problems.
I have similar issue. Does factory reset works for you? Or can i downgrade to previous firmware?
QUOTE="Widmark, post: 407538, member: 8392"]Could be coincidence but since installing 3.0.0.4.382_50470 a few days ago my RT-A66U wifi lost connectivity a few times. Anybody else?
**UPDATED - Clarified that the A66U wifi was stalled out but the router itself did not reboot based on the log reading**[/QUOTE]
I'm going to perform a firmware update on a AC66U I beleive haven't been updated in many years. I don't have access to the router yet, so I don't know the actual firmware version.
I've tried to find info regarding this, but have not come to a conclusion yet:
Can I go straight to latest firmware?
Will update this post if I find the answer myself.
Edit:
https://github.com/RMerl/asuswrt-merlin/wiki/Installation
"Starting with Asus's 3.0.0.4.380_3000, a new firmware format is used. To flash Asuswrt-Merlin on one of these newer firmwares, you will need 380.61 or newer. Likewise, downgrading to an older version is not supported. (Try firmware recovery mode if you really need to downgrade.)"
So, I'll try flashing first stable 380 ASUS fw if flashing straight to latest fw fails.
I flashed my RT-AC66U with 3.0.0.4.382_50470 yesterday, did a factory default reset. Today I have noticed that my RT-AC66U has rebooted on its own. I'll observe further and inform if the issue will occurring repeatedly.
mine has been rebooting roughly daily since flashing this a few months ago
its was factory reset after flash and put into ap mode
then below set via telnet
nothing else has been done
nvram set time_zone_dst="1"
nvram set time_zone="GMT0DST_1"
nvram set time_zone_dstoff="M3.2.0/2,M10.2.0/2"
nvram set wollist="edit"
nvram set ntp_server0="uk.pool.ntp.org"
nvram set ntp_server1="time.nist.gov"
nvram set upnp_secure="0"
nvram set lan_stp="0"
nvram set usb_path1_diskmon_freq="2"
nvram set usb_path2_diskmon_freq="2"
nvram set usb_path1_diskmon_freq_time="1>0>6"
nvram set usb_path2_diskmon_freq_time="1>0>6"
nvram set wl0_bw="2"
nvram set wl0_chanspec="9l"
nvram set wl0_crypto="aes"
nvram set wl0_ssid="Edit"
nvram set wl0_wpa_psk="edit"
nvram set wl0_wps_config_state="0"
nvram set wl0_wps_mode="disabled"
nvram set wl1_bw="3"
nvram set wl1_chanspec="116/80"
nvram set wl1_crypto="aes"
nvram set wl1_ssid="Edit 5Ghz"
nvram set wl1_wpa_psk="edit"
nvram set wl1_wps_config_state="0"
nvram set wl1_wps_mode="disabled"
nvram set wl1_wps_reg="enabled"
nvram set wps_enable="0"
nvram set wps_enable_x="0"
nvram set wl0_plcphdr="short"
nvram set daapd_enable="0"
nvram set dms_enable="0"
nvram set daapd_friendly_name="Edit"
nvram set dms_friendly_name="Edit"
nvram set computer_name="edit"
nvram set acc_list="edit"
nvram set acc_num="2"
nvram set lan_domain="edit"
nvram set btn_ez_radiotoggle="1"
nvram set custom_clientlist="edit"
nvram commit
reboot
I have checked today and the uptime of mine RT-AC66U is 4 days 23 hours. So, it seems that the router is working good. Almost everything is configured by default. I use manual address assignment (DHCP reservation) functionality only.
