Asus RT N66U + FTP
sitecom
I've got this router and having found out that it has a microsd slot, I would like to know how I can get access to it via ftp or similar as its tucked away under the case. Im on the latest build will be getting a micro sd card and formatting it to ext2.
Is there a guide on this or can soone write some instructions please?
This may void your warranty!
http://www.youtube.com/watch?v=hlWFkyHNHUg
NOTE:Use an old credit card!, and if you slightly round off the square edges on the top male plastic tabs it makes it easier to access/remove the Micro SD card in the future, although I have only needed to re-access the card once in 14 months.
P.S. I strongly suggest that you label the Micro SD card to ensure that it always gets mounted (reliably) on the same /mnt/xxxxx
Regards,
So after I've got a card in there, how do I configure an ftp client I.e filezilla to transfer to and from it?
