asus RT-N66U vs apple AIRPORT EXTREME
LostSignal
hi,
i don't know what buy between this two router.
the asus don't support hub usb,so i can use only two external hd without a custom rom (if this feature is true).
the apple instead don't have upnp support and a worst coverage area.
what is the better choise?
thanks
I think these questions can only be answered buy you. In your network which of these features do you need? What can you live without? There are people which run both of these routers but not in your network so it is very hard to discern which is best for you.
hi,
thanks
THe apple does have upnp support. So that doesn't matter. I used to have a Timecapsule, i ended up buying an asus rt-ac66u, because i wanted a configurable firewall.
THe true this if you want a plug and play thing, and you have all Apple stuff, then the TImeCapsule or airport extreme is your best bet.
(THis is all assuming you don't want any different features, like QOS, or a highly configurable firewall, both things that i wanted)
