After running 43181 w/o problems for a couple of days, the same problems resurfaced as with the 43170; nodes dropping connection an only connecting to 2.4Ghz. So quickly reverted to 42095 again.
I agree with this! The reason I got this mesh router a few months ago is because I needed a faster one than my TP-Link Deco 5 and the CT8 and XT8 came highly recommended by Wirecutter. But these firmware updates breaking the router's basic functions is just too much. The return period has already elapsed for me. I might just call this whole ordeal an expensive loss and move on. At the same time it sprung me to action. I've decided to wire the whole house and then reassess. My pair of XT8s might still be worth keeping if they can maintain connection thru a wired backhaul. But I'm really thinking of switching to the Ubiquiti line. I'm sure those have a list of issues, too.I have to say that this firmware-roulette is starting to get a bit tiresome, specially after the long beta test process some of us participated in. I don't know which routers or brands to recommend anymore if somebody were to ask me for a router recommendation.
What are you using as your main router?well, the 42095 firmware is working great for me in AP mode so I'm just going to stick with that for a while I guess. If I were using the XT8 as my main router I would be mightily annoyed with not being able to install the latest security patches. I can only imagine how the average consumer is coping and how much harm these issues are doing to the brand which is a shame. I was also thinking of switching to ubiquiti/amplifi but they didn't seem to meet my needs and unless i'm mistaken you have to create an account with them to be able to use the routers which I dislike. I even bought a couple of the latest TP-link dedicated access points a while ago but they have high latency and didn't have wireless mesh yet. aaaanyways....
Sounds like the issue I've been having with just a few smart lights! - Going back to 40295 as a test.Upgraded my my three XT8's, same problems as before, then reset my primary node to factory defaults (to rule out other mesh nodes as an issue, they weren't even connected anymore), same broken behavior as before:
40295:
"Alexa turn off living room" -> 4 TP-lInk lightbulbs, 2 TP-Link Outlets, a Denon receiver, and a Sony TV all turn off at the same time.
43169, 43170, 43181:
"Alexa turn off living room" -> Sometimes all devices turn off. Sometimes my Echo (1st gen) gets stuck, and some devices will accept the command, and it'll pause, and either eventually get to them all or just give up.
Same behavior happens regardless of command it seems, just changing colors on just the lightbulbs (LB 130's) has the same issues, where it seems to be throttling the commands somehow, until they all complete, or timeout.
Thanks, but care to share the brand and model?a dedicated firewall/router machine
I had some very similar experiences with a TP-Link smart switch (HS200) running on 43181 as well. I monitored the device with a continuous ping and it would be all over the place (huge latency and substantial packet loss). As soon as I went back to 42095 and ran the same monitoring, the latency and packet loss were gone.Upgraded my my three XT8's, same problems as before, then reset my primary node to factory defaults (to rule out other mesh nodes as an issue, they weren't even connected anymore), same broken behavior as before:
40295:
Perhaps some kind of setting/config in the newer firmware that just doesn't play nice with the TP-Link or other devices?
It's not just TP-Link hardware, the problems most seem to be having related to the wireless backhaul being unstable, which is simply unacceptable for a home working set up. It seems to affect all firmware post 43169 inc 43181. Interestingly, the behaviour is harder to spot in 43181 than in earlier firmware, simply because the outages are shorter, but it's long enough to knock out a video call or remote VM connection. My own anecdotal experience suggests there are greater problems with the paired sets vs independent units. 43181 also runs a slower connection to the nodes (in my case I was getting approx 250-300 on my nodes, which compares with 350-500 on 42095).I had some very similar experiences with a TP-Link smart switch (HS200) running on 43181 as well. I monitored the device with a continuous ping and it would be all over the place (huge latency and substantial packet loss). As soon as I went back to 42095 and ran the same monitoring, the latency and packet loss were gone.
The majority of my other devices seemed ok on 43181, but that one switches extreme behavior still caused me to revert to 42095 for stability.
Welcome To SNBForums
