ASUS ZenWiFi BT8P - Supported?
tudousi
Hi everyone,
I'm new to this forum. I wanted to find out if it's possible to flash my newly purchased ZenWiFi BT8 with the Merlin firmware. Unfortunately I didn't do enough research to know that there's some limitations to Asuswrt VPN. It seems like I have to use Merlin in order to utilize Shadowsocks etc. However, I couldn't find information about my router on the Merlin website nor in this forum.
Appreciate any guidance from the experts here. Thank you!
Not all Asus routers have Melin firmware available for them. I believe your BT8 is one that doesn't. You'll probably need to swap your router for one that will work with shadowsocks, or use an intermediate device to run the VPN client.
I think it's dependent on what chips it uses, and the BT8 and BT6 from what I've seen don't have the necessary Broadcom hardware.
Thank you for your advice, confirms my suspicions :(
What router would the community recommend at this point?
Not familiar at all with shadowsocks, but it seems you can install it on a raspberry pi placed in front of the router...
