Autoreboot when update
  • Thread starter Thread starter joma_po
  • Start date Start date
J
joma_po
Guest
Hi, when i update my rt-ac68u, router reboot automatically and i use ASUS firmware restoration tool.
What can i do for solve this problem?
Thanks.
Enviado desde mi iPhone utilizando Tapatalk
We need much more information.
Which firmware were you running before you updated?
Which firmware did you try to update with?
I realise English is not you first language, but without a fuller description of the symptoms, we cannot understand where the problem is.
Why is it necessary to use the firmware recovery tool?
Thanks.
Is your router really a rt-ac68u? Or is it a converted T-Mobile router?
I have an Asus rt-ac68u rev. e1 and it is not a TMobile Router.
I was in Merlin 384.6 when updating to 384.8 router autoreboot every 40-50 seconds after flash finished . with Asus firmware restoration tool i repaired it. When i updated to 384.8_2 happend the same.
Sorry for my English!!
Regards.
Have you tried doing a factory default reset and reconfigure manually. Don't use a saved backup. I know, pain in the drain. If all else fails try it.
Ok, thanks for your help
