Tom Van Veen
I know how to setup and use the Bandwidth Limiter setting, but i'm looking for some clarification on how it works in regards to IP ranges and Access Points as I cannot test it here at work atm.
For example,
If I set a range of 192.168.1.0/24 under the bandwidth limiter with a max down of 10 mb/s and 1 mb/s upload, does this limit the bandwidth for EACH address 192.168.1.1->192.168.1.254 to 10 mb/s and 1 mb/s OR does it limit the sum of the entire range to the 10 mb/s and 1 mb/s?
This distinction is important because in the first scenario each device would have 10 mb/s down and 1 mb/s up. Or in the second scenario the sum of all devices cannot exceed 10 mb/s down and 1 mb/s down.
Also i'm looking to limit an entire AP using bandwidth limiter with the AP IP 192.168.2.1, when I put the AP ip in the bandwidth limiter would this limit each address in the AP DHCP pool to 10mb/s down each? or be the sum of all devices on that AP be limited to what I set?
My scenario:
I have my router on the main floor and an AP in the basement for tenants. I am trying to limit all traffic on the AP to a set value and leave the main router unlimited. The tenant only has access to the AP. The AP is connected to a port on the router. router pool is 192.168.1.xxx, AP pool is 192.168.2.xxx
For example,
My scenario:
