can I limit bandwidth for one specific device ?
boerlx
RT-AC68U, 378.55
Hello,
I noticed that when someone uploads a video to YouTube everything crawls to a standstill for every other users.
Is there a way to limit the upload bandwidth of a specific device/computer with Merlin?
Thanks.
sure set the client bandwidth limits in the qos section
adaptive qos / qos - enable - select bandwidth limiter
select device and set upload and download limits
apply and your done
He'll need to upgrade his firmware first. 378.55 is old, and doesn't include the Bandwidth Limiter.
I'm wondering if this is a low-level bug in the Broadcom SDK release, as I hear about it much across all vendors that build on the Broadcom SDK (most, not all, do...).
yopu can limit the bandwidth with out the bandwidth limiter
QOS>User Defined proirtues
Just setup your lowest to highest in there and them put the mac address of the device ou want to limit in QOS and pick highest to low, this is how it been doing it and it works fine
you misunderstand what the difference between qos and bandwidth limiting is
qos is in demand and usually to late to avoid lag and saturation
bandwidth limiting is a fixed amount of cake and you get no more
well I just downgraded from Merlin 380.58 as the router would freeze about once a week. I've been advised to stick with 378.55
No i dont this how i limit the bandwidth of my devices, the devices I set to lowest which is 5% of bandwidth only get about 5mbit this way, and the devices i set to Medium only get 50% only get 50mbit on those devices.
Again, this should not be a problem - which brings me back to Broadcom's SDK with their secret sauce...
