Can no longer use any channels in Band A UNI-II Lower
medwatt
When I first got the AC66U_B1 router, I noticed that the 5GHz signal takes a long time before any of my devices can detect it. A member here suggested I should use channel 36 as channel 36 is not a DFS channel. That simple trick worked. However, today none of my devices were able to detect the 5GHz signal. I started changing channels and realized that I can detect any signal when the channels are set to channels 36, 40, 44, 48. Channels 52, 56, 60, 64 all work, but there's a slight delay of about 2 minutes after the 2.4GHz signal is detected. Can someone explain what's happening ?
Yes, but why have I lost the ability to use channels 36 to 48, which are supposedly the free channels.
Sorry, I misunderstood the question because of the typo:
...I can detect any signal when the channels are set to channels 36, 40, 44, 48.
I don't know the answer. What region are you in, US?
Do you have the "Auto select channel including band 1 channels" option? Perhaps you could trying unsetting and setting that.
https://www.snbforums.com/threads/what-are-band1-channels.25681/
Mine says "Auto select channels including DFS channels". But I don't use that. I manually selected channels 36, 40, 44, and 48. I couldn't detect the 5GHz signal despite waiting for more than 10 minutes.
What region are you in?
What channel do you see being used when you go to System Log > Wireless Log?
I bought the router from Amazon UK, but I live in South Africa. I want to emphasize that I have been using channel 36 all along. It was only yesterday that it stopped working.
OK. What about the information on the Wireless Log page?
Sorry, I wasn't home.
Here's my 5GHz setup page:
Here's the Wireless Log page:
Well, I'm out of ideas.
It might be worth changing the channel bandwidth from 20/40/80 to 20 just as an experiment.
