cant mount ext4 usb drive on N66U / but on AC56U (both same fw version)
heliosone
Hi
I can't mount a 1 tb Toshiba ext4 formatted drive (done on my AC56U) on my other router N66U (mount says invalid argument / syslog calls it unsupported features)
Both have the same fw version (380-65)
What can I do?
Thanks ahead for help!
thanks for your reply.
I was about to delete my post,as I discovered that same firmware versions have different linux kernel/version ,but maybe it holds the answers for someone else with the same quesion :)
