Changed DDNS service
Akki
Hi guys,
I was using only no-ip as ddns service but i changed last night to dnsomatic as i am also using opendns home as dns filter. As i understand , and it looks like its working i have added both of those services to dnsomatic and it looks good.
BUT, SSL sertificate is stuck in Updating.... looks like its caused but changing DDNS service
Searching the forums i found /sbin/le_acme , i run it from SSH but nothing really changed.
Is there a way to force update without factory reset?
Thanks in advance!
I believe this is a well-known issue/bug. I also believe the bug mis-reports, making that "Updating" a false indicator that something is wrong.
So your suggestion too would be to do factory reset , setup new DDNS and ask for new certificate?
Let's Encrypt won't work with DNS-o-Matic since you are not using a real DDNS hostname, but a meta-service instead.
Thanks Merlin,
I will then go back and setup DDNS to no-ip, and manually update IP for opendns filtering.
Tunnelbroker.net has been working brilliantly for me. Set up a free account and they walk you through it quickly and painlessly
