Configure Cisco RV134W to use with Internet and IPTV through VLANs
mscbsg
Does anyone has any experience on Cisco RV134W Small Business Router? I am trying to configure the RV134W to connect to my Service Provider's Internet and IPTV services which runs on VLAN10, & VLAN 20 with 802.1p priority respectively. The Internet setting given by the ISP are:
Internet: VLAN 10
IPTV: VLAN 20, 802.1p Priority 4
I have managed to get the Internet up and running but not the IPTV. When using my Cisco SG200-08 Smart Switch terminating the WAN connections, it is tested working, so the problem has to be the configuration of the RV134W. Please see diagram below on my configuration, need advice on how to configure.
Thanks.
Internet: VLAN 10
Thanks.
I have seen routers firewall networks which are not in the primary scope of the DHCP or static IP address of the router. Maybe you need an allow access list for the IPTV network. I have no experience with IPTV. But if the switch is working and the router is not sounds like a firewall issue.
