Voxel
Part of the Furniture
Continuation of
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-62sf.50417/
New version of my custom firmware build: 1.0.2.63SF.
Changes (vs 1.0.2.62SF):
1. Integration of changes from the stock v. 1.0.2.62 including:
for details.
3. curl package is upgraded 7.62.0->7.63.0.
4. dbus package is upgraded 1.12.10->1.12.12.
5. e2fsprogs package is upgraded 1.44.4->1.44.5.
6. jansson package is upgraded 2.11->2.12.
7. libgpg-error package is upgraded 1.32->1.34.
8. libxml2 package is upgraded 2.9.8->2.9.9.
9. sqlite package is upgraded 3250300->3260000.
10. wget package is upgraded 1.20->1.20.1.
11. dnsmasq: synchronization of codes with stock 1.0.2.62 (R9000 codes were used in my previous version).
12. OpenSSL: old libraries 0.9.8 are added to fix NG bug (/bin/fbwifi).
13. NG Downloader: ftp/http downloading issue is fixed.
14. NG bugs corrections fixed in my previous versions are included.
15. NG version of OpenVPN client is removed (conflicting with my version of OpenVPN client).
16. Funjsq service is removed:
18. Host tools: two components are upgraded.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Thanks to percy3 for his help with testing.
P.S.
There are several opinions found by me in Internet that Voxel’s FW is just a stock firmware with a bit more attractive icons. I cannot provide full statistics but FYI: stock firmware is using third party GPL packages, about 143 of them are used in my version. And about 105 of them are upgraded/changed/added/bugfixed. So I think that at least 73 per cents of firmware internals is different. This is w/o accounting specific changes such as different toolchain/host-tools or optimized for IPQ806x compiler options, -O2, boosting OpenSSL etc. Just FYI. My version is my vision re: what I’d like to have from a stock firmware.
P.P.S.
Especial thanks to NETGEAR Guy for his help of getting GPL sources from NG engineering team. I really think that NG should appreciate this Gentleman and encourage him.
Also a lot of thanks to kamoj who provides significant support of my fw users.
Voxel.
- a login password enhancement in the router web interface to support a more secure password (no saving passwords in NVRAM in the plain text form).
- fixing the issue where the speed test in the QoS page always displays a zero number.
- 22 QoS packages are changed to provide synchronization with a latest version (so even if your QoS page displays "Release Date: October 23, 2017": de facto there are a lot of changes in the QoS internals).
for details.
Guys from China: I am really sorry, please use a stock version if you need exactly this version of OpenVPN client, my knowledge of Chinese is close to zero to understand this service description/features from this: https://www.funjsq.com/
17. Toolchain: gdb is upgraded to 8.2.1.18. Host tools: two components are upgraded.
The link is:
P.S.
P.P.S.
Voxel.
