Custom firmware build for R7800 v. 1.0.2.74.1SF
Voxel
Part of the Furniture
Continuation of
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-72sf.59894/
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-73sf.60710/
New version of my custom firmware build: 1.0.2.74.1SF.
Changes (vs 1.0.2.74SF):
1. Partial selective integration of changes from the stock v. 1.0.2.68
to support FCC channels 136, 140, and 144.​
2. Default ReadyCLOUD version is upgraded 20180619->20191014.
3. ubus package is upgraded 2019-12-27->2020-01-05.
4. e2fsprogs package is upgraded 1.44.5->1.45.5.
5. curl package is upgraded 7.67.0->7.68.0.
6. Host tools (e2fspogs): is upgraded to 1.45.5.
Changes (1.0.2.74SF vs 1.0.2.73SF):
1. OpenSSL v. 1.0.2 package is upgraded 1.0.2t->1.0.2u.
2. uci package is upgraded 2019-11-14->2019-12-12.
3. libubox package is upgraded 2019-11-24->2019-12-28.
4. ubus package is upgraded 2018-10-06->2019-12-27.
5. DNSCrypt Proxy v.2 is upgraded 2.0.35->2.0.36.
6. logrotate package is upgrader 3.8.1->3.15.0.
7. ffmpeg package is upgraded 3.4.6->3.4.7.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
@Voxel
Does it include support for DHCP 60/61 ?
No. One of the reason: technical problems to integrate this into my build. Details: I have to integrate almost full changes from the stock 1.0.2.68 to support this, but I'd like to avoid it because of new bugs.
Please use kamoj add-on to support for DHCP 60/61
https://www.snbforums.com/threads/kamoj-add-on-v5-for-netgear-r7800-x4s-and-r9000-x10.60590/
  • Cron Jobs
  • DHCP Options 60 and 61
  • Congestion Control
Voxel.
we welcome our new overlords
No. Not overlords.
Voxel.
Can you implement another QOS such as cake besides the fq_codel used in the stock firmware?
cake needs backporting to the kernel used. I'm not sure if Voxel will do it. My guess is he won't
hello all.
i have a question. be mindful i am very know to this custom firmware.
i am getting Eufy cam 2 c system, i am going to install 2TB HDD to R7800 .. doe this custom firmware have a better RTSP then the stock firmware?
hello all.
I have same type of question as well. I am using 128GB SSD /128GB Flash Drive (one at a time) on my R7800. But in my experience it is very unstable. USB Storage gets disconnected frequently. Need to restart router to solve the issue. Recommended Max USB Storage to be used is 64BG may be. Can USB storage support be improved in any way @Voxel?
I am using three IP cameras with RTSP stream They are working fine. Did not try stock firmware.
Also, I am using three different USB: two 64GB flash drives and one 2TB HDD drive. All of them are formatted as ext4. No any disconnects. At all. What FS do you use?
Voxel.
Voxel.
both are formatted as NTFS. Is that the problem..?
Thanks for quick response.
