DDNS and LetsEncrypt
kramttocs
UPDATE: RT-AX86U en route!
I have a domain name with GoDaddy that is managed(?) by Google Workspaces.
Currently I have the dns records in GoDaddy set to DNSExit values.
DNS-O-Matic updates DNSExist (and OpenDN).
DDNS in the R7000* router updates via DNS-O-Matic and all works great. SSL is None.
I'd like to get Let's Encrypt working though and have it all handled by the router. I don't know much at all about this but I do understand why Let's Encrypt won't work with DNS-O-Matic.
What is the best option to allow me to keep Google Workspaces, use one of the DDNS options in the router dropdown, and have Let's Encrypt work automatically?
*getting new hardware due to learning about legality
What program are you using??
This is for some applications (Home Assistant being one) that I am needing external access, which I have , but also SSL.
As a side note, I did read the FAQ before posting and sadly learned that the asuswrt I am using on my router should not be used. Had no idea.
Browsing for a new router now as I want asuswrt-merlin but I also want to be legal in it. Hope my question still stands as I am not reporting an issue but rather what is the best router controlled ddns/le given my GoDaddy domain and Google Workspaces.
I se you have modified your post and removed R7000 router.
I did - not because I am trying to hide it but rather because I am not going to be on that hardware for much longer now that I know what I know and I didn't want that to impact the discussion. Edit: I added it back with a note.
At this point, I am basically a soon to be user of asuswrt-merlin and looking for a recommendation given what I have currently with my domain and what works best with asuswrt-merlin.
RT-AX86U en route!
Now that I am on the up and up :), any help with my question?
