Deluge errors 384.13_8 on an Asus RT-AC87U
Morphy99
Hi I wondering if anyone had any ideas why my deluge is throwing up these errors? I've installed as per the wiki and it installed but I had this locale error when installing the webui:
Unable to initialize gettext/locale!
'ngettext'
Traceback (most recent call last):
File "/opt/lib/python3.8/site-packages/deluge/i18n/util.py", line 118, in setup_translation
builtins.__dict__['_n'] = builtins.__dict__['ngettext']
KeyError: 'ngettext'
It seems to be running and working however I get this error when starting deluged:
/opt/etc/init.d/S81deluge-web stopUnhandled error in Deferred:
10:09:24 [CRITICAL][twisted :154 ] Unhandled error in Deferred:
File "/base.py", line 1292, in mainLoop
File "/base.py", line 913, in runUntilCurrent
File "/defer.py", line 460, in callback
File "/defer.py", line 568, in _startRunCallbacks
--- <exception caught="" here=""> ---
File "/defer.py", line 654, in _runCallbacks
File "/task.py", line 866, in <lambda>
File "/opt/lib/python3.8/site-packages/deluge/core/torrentmanager.py", line 232, in start
self.archive_state('Bad shutdown detected so archiving state files')
File "/opt/lib/python3.8/site-packages/deluge/core/torrentmanager.py", line 1168, in archive_state
archive_files('state', arc_filepaths, message=message)
File "/opt/lib/python3.8/site-packages/deluge/common.py", line 198, in archive_files
with tarfile.open(arc_filepath, 'w:' + arc_comp) as tar:
File "/tarfile.py", line 1617, in open
File "/tarfile.py", line 1725, in xzopen
File "/lzma.py", line 111, in __init__
builtins.MemoryError:
Temporarily disabling observer LegacyLogObserverWrapper(<bound method="" twistedloggingobserver.emit="" of="" <deluge.log.twistedloggingobserver="" object="" at="" 0xa71bd0="">>) due to exception: [Failure instance: Traceback: <class 'typeerror'="">: findCaller() takes from 1 to 2 positional arguments but 3 were given
/defer.py:568:_startRunCallbacks
/defer.py:962:__del__
/_logger.py:190:failure
/_logger.py:144:emit
/_observer.py:131:__call__
/_legacy.py:93:__call__
/opt/lib/python3.8/site-packages/deluge/log.py:204:emit
/__init__.py:1481:critical
/__init__.py:1565:_log
File "/defer.py", line 962, in __del__
File "/_logger.py", line 190, in failure
File "/_logger.py", line 144, in emit
File "/_observer.py", line 131, in __call__
File "/_legacy.py", line 93, in __call__
File "/opt/lib/python3.8/site-packages/deluge/log.py", line 204, in emit
getattr(LoggingLoggerClass, event_dict['log_level'].name)(
File "/__init__.py", line 1481, in critical
File "/__init__.py", line 1565, in _log
builtins.TypeError: findCaller() takes from 1 to 2 positional arguments but 3 were given
This will keep popping up if I leave SSH logged in. I had a pretty major problem the other day where I ran out of memory and to reboot the router. I'm wondering if these issues are related.
EDIT: So I've solved the error with deluged starting up, must have been a corrupt config file somewhere from power loss or something.
I stopped deluged
/opt/etc/init.d/S80deluged stop
Backed up the /opt/etc/deluge folder
Removed it then copied back a few .conf files I needed. All good now. Still getting the locale error with deluge-web though.
