“--dhcp-option DNS” vs. “--dns args” (OVPN)
JTnola
--dns args
When should you use "--dns”? How does it function differently than “dhcp-option”? Is its implementation vpn provider-specific?
When you use
--dns server n transport DoT
does it magically encrypt any DNS queries routed over the tunnel, or what actually happens?
I use “--dhcp-option” all the time
I’ve never used "--dns option"
could you point us to a useful resource to help understand? Thank you!
I think the majority of the options would only be relevant in a private VPN setup, e.g. LAN to LAN. When connecting to a commercial VPN provider like NordVPN the only --dhcp-option that seems useful is DNS (and perhaps DOMAIN). The new --dns options seem more aimed at setting environment variables that can be used in scripts.
What options do you use?
dhcp-option DNS 9.9.9.9
dhcp-option DNS 149.112.112.112
TanyaC Using OpenVPN with VPN and local area network with block-outsde-dns VPN 0
