Hi guys
So I'm contemplating buying either the dir 822 or the 823 from d-link... both fairly inexpensive, at least on aliexpress (at about 30 usd) and both AC1200 routers, which is good. I actually don't need them for their ac compliance but more for that fact they are cheap and transmit 5ghz on 802.11n, which their manuals say they do. Sorry, the manual for 822 says it does, for 823 I'm only guessing it would do, since I cannot find this router anywhere on any d-link site. The 822 is in Canada, but 823 is nowhere. So firstly - any ideas where it is so that I could also look at its specs? And also would you recommend the 822 or 823? I know they are both not the greatest out there, but for the 30 usd and free shipping they are ok. I'm also buying them with the idea that soon I might have clients compliant with the AC standard, so I said to myself - might as well buy a router that supports that too. As of now, my clients can run on 5ghz on 802.11a and 802.11n and clearly I'd go for 'n' cos it's faster and newer.
My first and main concern was ofc interference. That's why I opted for the 5ghz. As it turned out, the DIR series of d-link runs only on the 5ghz U-NII-1, which in Europe (where I'm based) equates to an available selection of only 4 channels - 36,40,44,48, which is not bad and is definitely better than the crazy-overcrowded 2.4ghz, but still I'd rather have a router that (at least in Europe) runs also on the U-NII-2A band (channels 52, 56, 60, 64) and the U-NII-2C band (channels 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140) but to get that you need extra $$$. So for now, sth that levitates around 30$ and runs on the U-NII-1 (and is N and AC compatible) would fit my needs. That's why I thought the dir822 and 823 are not too shabby, but wanted to hear more opinions. And again - where on Earth is the dir823???
