Diversion Diversion Makes Router Hang Each Time WAN Restart
KingBravery
Hi guys,
Is it normal each time WAN restart or Router reboot, it will be hang up and make the connection stuck?
Sometimes LAN adapter also cant get IP when the cpu usage hits 100% for below process.
" grep -wq ^:: /opt/share/diversion/list/blacklist "
Is there a way to prevent this happen?
Thank you
Maybe your blacklist is corrupted. What size is it?
ls -l /opt/share/diversion/list/blacklist
It shows like below:
-rw-rw-rw- 1 admin root 79081472 Feb 12 02:25 /opt/share/diversion/list/blacklist
Ouch. I doubt you've manually blocked that many hosts. It would probably help fix the underlying problem if you provide a small bit of the file contents then zero out the file.
head /opt/share/diversion/list/blacklist
true > /opt/share/diversion/list/blacklist
service restart_dnsmasq
wow. nice coding you have.
After launch it, I restart WAN connection and the usage not reach 100% anymore and the high usage only for short time.
If it happen again, just type that code again, right?
Actually, I don't manually block anything. I don't know if I'm setup it wrongly.
Anyway, Thank you dave14305 for your help.
