DLNA - Does it work well on any routers?
mogulman
So I tried a few of the newer routers to replace my old dying router. I wanted one with DLNA USB support, so that I didn't have to leave a PC on to share some picture music video.
Belkin N750, has a 3000 file limit for media sharing
Netgear WNDR4000 DLNA seems broken. It keeps adding and removing files to the library.
Linksys E4200 (v1) - Seemed to work, but was very slow.
I've read user reviews on different sites. It seems like most of the routers have issues with DLNA. Are there any good DLNA routers?
Or should I just copy all my media to a PC....and leave it there and forget about that function in a router...
Essentially, no.
Yes, or get a newer model nas with sufficient cpu power to effectively support dlna.
Routers are specialized low-power devices. Yes manfacturers have been adding extra features such as usb/dlna/ftp support and whatever else, however you are still dealing with a device that is probably less powerful than your cell phone, and with the resulting performance.
Ok.. I'm just copying all this stuff to a drive on my HTPC, then and using WMP to stream. I leave that PC on 24/7 anyway.
