Diversion dnsmasq.log file empty
tratek
I've noticed that dnsmasq.log file is empty and I'm unable to see which hosts are called/blocked in Diversion
==>> logging is on yet the file is empty:
-rw-rw---- 1 nobody root 0 Mar 18 12:26 dnsmasq.log
Any hints what's missing/wrong?
Disable and re-enable logging, see what happens.
Do you actually have dnsmasq logging enabled in Diversion?
From ssh run "cru l" (without the quotes).
You should find 4 entries for Diversion (and 4 for uiDivStats, if that's installed)
adrim@RT-AX86U_Pro-0D20:/tmp/home/root# cru l
*/2 * * * * /etc/openvpn/server1/vpn-watchdog1.sh #CheckVPNServer1#
*/2 * * * * /etc/openvpn/server2/vpn-watchdog2.sh #CheckVPNServer2#
5 0 * * * /opt/sbin/logrotate /opt/etc/logrotate.conf >> /opt/tmp/logrotate.daily 2>&1 #logrotate#
25 1 * * * sh /jffs/scripts/firewall banmalware #Skynet_banmalware#
19 1 * * Mon sh /jffs/scripts/firewall update #Skynet_autoupdate#
0 * * * * sh /jffs/scripts/firewall save #Skynet_save#
40 */12 * * * sh /jffs/scripts/firewall debug genstats #Skynet_genstats#
00 2 * * Thu /bin/sh /opt/share/diversion/file/update-bl.div reset #Diversion_UpdateBL#
20 5 * * * /bin/sh /opt/share/diversion/file/rotate-logs.div #Diversion_RotateLogs#
20 17 * * * diversion count_ads count #Diversion_CountAds#
Run this in the terminal:
grep log /etc/dnsmasq.conf
See if your USB is full.
cd /opt/var/log
df -k .
interesting, indeed. I will need to investigate what has filled the file system.
adrim@RT-AX86U_Pro-0D20:/tmp/mnt/sda5/entware/var/log# df -k .
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda5 3038544 2879944 0 100% /tmp/mnt/sda5
I've now deleted (2GB) and recreated Swap (1GB)
/dev/sda5 3038544 1831492 1033484 64% /tmp/mnt/sda5
Logging in back to normal.
Thanks!
adrim@RT-AX86U_Pro-0D20:/tmp/mnt/sda5/entware/share/uiDivStats.d# ls -lh
-rw-rw-rw- 1 adrim root 472 Jan 2 11:00 SQLData.js
drwxrwxrwx 2 adrim root 4.0K Jan 2 11:01 csv
-rw-r--r-- 1 adrim root 548.2M Jan 2 11:00 dnsqueries.db
-rw-r--r-- 1 adrim root 6.3M Oct 27 00:01 dnsqueries.db.bak
on my other router =>
adrim@RT-AX56U-3740:/tmp/mnt/sda1/entware/share/uiDivStats.d# ls -lh
-rw-rw-rw- 1 adrim root 471 Dec 22 12:00 SQLData.js
drwxrwxrwx 2 adrim root 1.0K Dec 22 12:38 csv
-rw-r--r-- 1 adrim root 1.2G Jan 14 08:59 dnsqueries.db
-rw-r--r-- 1 adrim root 3.8M Aug 1 2022 dnsqueries.db.bak
how to uninstall uiDivStats as it exits when selecting j5 from menu
adrim@RT-AX86U_Pro-0D20:/tmp/mnt/sda5/entware/share/uiDivStats.d# /jffs/scripts/uiDivStats uninstall
Removing uiDivStats...
Do you want to delete uiDivStats stats and config? (y/n) y
Uninstall completed
that solves the problem ;)
Reinstall uiDivStats now. One of the cron jobs it installs trims the DB file (uiDivStats_trim). I don't see any of the four uiDivStats in your cru list and only two for diversion, meaning either it didn't install correctly, or you've had some of the mystery disappearing cron jobs discussed here:
The disappearing cron jobs is fixed in the current 388.7_alpha1. I wouldn't normally recommend an alpha but this one is proving stable and has a specific fix I feel is needed here.
1) uiDivStats reinstalled
2) cron updated:
4-59/5 * * * * /jffs/scripts/uiDivStats flushtodb #uiDivStats_flushtodb#
3) I've set the data retention to 14d
4) I'll keep monitoring it for the next couple of days to see how fast data volume grows
at this point - solved;=)
These are the four uidivstats cron jobs I see, and would expect you to see as well:
0 1-23 * * * /jffs/scripts/uiDivStats generate #uiDivStats_generate#
1 0 * * * /jffs/scripts/uiDivStats trimdb #uiDivStats_trim#
* * * * * /jffs/scripts/uiDivStats querylog #uiDivStats_querylog#
The trim one is important as it keeps dnsmasq.db down to a reasonable size.
Why they're not all showing is a mystery right now. I wonder if they'd all show up after a reboot(?).
find / -size +10000 -exec ls -al {} \; | sort -k 5,5 -n | tail -15
du -k / | sort -k 1,1 -n | tail -15
I resized my USB filesystems from 4 GB to 8 GB. It is like open heart surgery but Partition Wizard was successful.
correct, I see 4:
correct, I see 4:
Keep an eye on. If you notice strange things again check for these four jobs.
