Download Master blocklist
Megahurtz
I installed Download Master on my AX6000. I was able to ssh into the router and modify the settings.json file for Download Master to enable the block list as well as specify a URL to use. I entered "https://github.com/Naunter/BT_BlockLists/raw/master/bt_blocklists.gz" for the URL and tried stopping/starting Download Master and also rebooting the router.
Nothing appears in Download2/config/blocklists however. How can I get Download Master to process the block list?
Don't know, so asking, does Download Master automatically uncompress the file when the server is sending "application/octet-stream" instead of "application/gzip" for the Content-Type response header (as is the case at this time)?
Might could fetch the file, gzip -d it, and feed the result to the router, if nothing else.
It doesn't look like Download Master is downloading anything by itself. The blocklists directory is always empty. I manually wget'd that URL I plugged in to the config file and it pulled down the .gz file. Download Master didn't seem to do anything with that either.
I gzip -d'd that file and it gave me a bt_blocklists file. Stopping the Download Master service and restarting it looks like it processed that, because now I also have a bt_blocklists.bin file that didn't exist before. So I presume it worked and there is a block list in place now, but I still can't get Download Master to automatically download and process the file.
N AI mesh node not aligned with master ASUS Wi-Fi 13
