dsl-ac68u keeps crashing
tuxki
Hello
Every Day my connection crashes and I don't know how to fix it. I assume, it's because of the "status: 0, reason: Class xx frame received from nonauthenticated station (6)" error leading to:
pppd[386]: Serial link appears to be disconnected.
WAN Connection: Fail to connect with some issues.
nat: apply redirect rules
pppd[386]: Connection terminated.
pppd[386]: Modem hangup
What does it mean and how can I fix it?
Info:
DSL-AC68U
DSL Firmware Version 1.0.4.9
DSL Driver Version FwVer:5.5.2.11_B_A60901 HwVer:T14.F7_0.2
AiMesh router
Current Version : 3.0.0.4.384_81981-g632ffdf
Jan 21 18:08:33 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 1 ###, status: Successful (0)
Jan 21 18:08:33 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 1 ###, status: Successful (0)
Jan 21 19:53:21 syslog: wlceventd_proc_event(459): eth2: Deauth_ind ### Client 2 ###, status: 0, reason: Disassociated due to inactivity (4)
Jan 21 21:53:38 syslog: wlceventd_proc_event(476): eth1: Disassoc ### Client 3 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 21 21:53:38 syslog: wlceventd_proc_event(459): eth1: Deauth_ind ### Client 3 ###, status: 0, reason: Class 2 frame received from nonauthenticated station (6)
Jan 21 22:13:42 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 3 ###, status: Successful (0)
Jan 21 22:13:42 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 3 ###, status: Successful (0)
Jan 21 23:53:33 syslog: wlceventd_proc_event(476): eth1: Disassoc ### Client 3 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 00:13:41 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 3 ###, status: Successful (0)
Jan 22 00:13:41 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 3 ###, status: Successful (0)
Jan 22 01:53:32 syslog: wlceventd_proc_event(476): eth1: Disassoc ### Client 3 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 01:53:32 syslog: wlceventd_proc_event(459): eth1: Deauth_ind ### Client 3 ###, status: 0, reason: Class 2 frame received from nonauthenticated station (6)
Jan 22 02:13:39 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 3 ###, status: Successful (0)
Jan 22 02:13:39 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 3 ###, status: Successful (0)
Jan 22 04:54:02 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 4 ###, status: Successful (0)
Jan 22 04:54:02 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 4 ###, status: Successful (0)
Jan 22 04:54:33 syslog: wlceventd_proc_event(476): eth1: Disassoc ### Client 4 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 05:53:23 syslog: wlceventd_proc_event(476): eth1: Disassoc ### Client 3 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 06:13:30 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 3 ###, status: Successful (0)
Jan 22 06:13:30 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 3 ###, status: Successful (0)
Jan 22 08:21:37 syslog: wlceventd_proc_event(459): eth1: Deauth_ind ### Client 5 ###, status: 0, reason: Disassociated due to inactivity (4)
Jan 22 08:39:45 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 5 ###, status: Successful (0)
Jan 22 08:39:45 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 5 ###, status: Successful (0)
Jan 22 08:53:18 syslog: wlceventd_proc_event(476): eth1: Disassoc ### Client 3 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 09:13:25 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 3 ###, status: Successful (0)
Jan 22 09:13:25 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 3 ###, status: Successful (0)
Jan 22 09:43:17 syslog: wlceventd_proc_event(476): eth1: Disassoc ### Client 3 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 11:31:38 syslog: wlceventd_proc_event(459): eth1: Deauth_ind ### Client 1 ###, status: 0, reason: Disassociated due to inactivity (4)
Jan 22 13:05:14 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 1 ###, status: Successful (0)
Jan 22 13:05:14 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 1 ###, status: Successful (0)
Jan 22 13:06:11 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 3 ###, status: Successful (0)
Jan 22 13:06:11 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 3 ###, status: Successful (0)
Jan 22 13:09:37 syslog: wlceventd_proc_event(459): eth1: Deauth_ind ### Client 1 ###, status: 0, reason: Disassociated due to inactivity (4)
Jan 22 13:31:22 syslog: wlceventd_proc_event(459): eth1: Deauth_ind ### Client 5 ###, status: 0, reason: Disassociated due to inactivity (4)
Jan 22 14:09:59 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 5 ###, status: Successful (0)
Jan 22 14:09:59 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 5 ###, status: Successful (0)
Jan 22 14:46:55 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 1 ###, status: Successful (0)
Jan 22 14:46:55 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 1 ###, status: Successful (0)
Jan 22 15:53:08 syslog: wlceventd_proc_event(476): eth1: Disassoc ### Client 3 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 16:00:51 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 4 ###, status: Successful (0)
Jan 22 16:00:52 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 4 ###, status: Successful (0)
Jan 22 16:18:37 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 3 ###, status: Successful (0)
Jan 22 16:18:37 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 3 ###, status: Successful (0)
Jan 22 16:21:37 syslog: wlceventd_proc_event(495): eth2: Auth ### Client 2 ###, status: Successful (0)
Jan 22 16:21:37 syslog: wlceventd_proc_event(524): eth2: Assoc ### Client 2 ###, status: Successful (0)
Jan 22 16:53:00 syslog: wlceventd_proc_event(476): eth1: Disassoc ### Client 3 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 17:13:04 syslog: wlceventd_proc_event(495): eth1: Auth ### Client 3 ###, status: Successful (0)
Jan 22 17:13:04 syslog: wlceventd_proc_event(524): eth1: Assoc ### Client 3 ###, status: Successful (0)
Jan 22 18:00:46 syslog: wlceventd_proc_event(476): eth2: Disassoc ### Client 2 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 18:00:46 syslog: wlceventd_proc_event(459): eth2: Deauth_ind ### Client 2 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 18:00:48 syslog: wlceventd_proc_event(495): eth2: Auth ### Client 2 ###, status: Successful (0)
Jan 22 18:00:48 syslog: wlceventd_proc_event(524): eth2: Assoc ### Client 2 ###, status: Successful (0)
Jan 22 18:00:55 pppd[386]: Serial link appears to be disconnected.
Jan 22 18:01:00 WAN Connection: Fail to connect with some issues.
Jan 22 18:01:01 nat: apply redirect rules
Jan 22 18:01:01 pppd[386]: Connection terminated.
Jan 22 18:01:01 pppd[386]: Modem hangup
Jan 22 18:01:07 syslog: wlceventd_proc_event(495): eth2: Auth ### Client 2 ###, status: Successful (0)
Jan 22 18:01:07 syslog: wlceventd_proc_event(524): eth2: Assoc ### Client 2 ###, status: Successful (0)
Jan 22 18:01:08 syslog: wlceventd_proc_event(476): eth2: Disassoc ### Client 2 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 18:01:08 syslog: wlceventd_proc_event(459): eth2: Deauth_ind ### Client 2 ###, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 22 18:01:08 syslog: wlceventd_proc_event(459): eth2: Deauth_ind ### Client 2 ###, status: 0, reason: Class 3 frame received from nonassociated station (7)
Jan 22 18:01:08 syslog: wlceventd_proc_event(495): eth2: Auth ### Client 2 ###, status: Successful (0)
Jan 22 18:01:08 syslog: wlceventd_proc_event(524): eth2: Assoc ### Client 2 ###, status: Successful (0)
Jan 22 18:01:12 pppd[386]: Connected to ########## via interface vlan3880
Jan 22 18:01:12 pppd[386]: Connect: ppp0 <--> vlan3880
Jan 22 18:01:12 pppd[386]: CHAP authentication succeeded
Jan 22 18:01:12 pppd[386]: peer from calling number ########## authorized
Jan 22 18:01:12 pppd[386]: local  IP address ##########
Jan 22 18:01:12 pppd[386]: remote IP address ##########
Jan 22 18:01:12 pppd[386]: primary   DNS address ##########
Jan 22 18:01:12 pppd[386]: secondary DNS address ##########1
Jan 22 18:01:12 nat: apply nat rules (/tmp/nat_rules_ppp0_vlan3880)
Jan 22 18:01:13 wan: finish adding multi routes
Jan 22 18:01:13 miniupnpd[18359]: shutting down MiniUPnPd
Jan 22 18:01:13 miniupnpd[2597]: version 1.9 started
Jan 22 18:01:13 miniupnpd[2597]: HTTP listening on port 38645
Jan 22 18:01:13 miniupnpd[2597]: Listening for NAT-PMP/PCP traffic on port 5351
Jan 22 18:01:15 WAN Connection: WAN was restored.
best regards
tuxki
perkeleeeeee
How many times a day does this happen?
Does the connection come back up by itself or do you have to enable it manually?
Hi Colin
Usually it happens once, sometimes twice a day. The connection establish itself "WAN Connection: WAN was restored".
If it only happens at approximately the same times each day then I suspect there is nothing wrong. It sounds like your ISP is only giving you a connection for 12 or 24 hours after which you have to reconnect (which the router does by itself automatically).
I would only suspect a problem if it were happening at random time intervals.
Dammit, I forgot about it. Indeed, my ISP refreshes my IP every 24h. IP refresh time (usually at 3am) just changed because I switched devices. I might fix this quite easily on my own. Worst case I have to call my ISP to change the ip assignment time.
Thank you Colin
best regards
tuxki
