Empty service state string. Bug?
Mikii
Hi. I am getting an empty service state status line. However, the VPN connection is working fine.
Any suggestion? This looks like a bug to me. I am on an RT-AX88U Pro with 3004.388.4.
Additionally, nvram get vpn_client3_state returns "0".
I noticed the same whenever the WIFI service is restarted (whatever the reason) on my RT-AX86U since 3004.388.4 release (did not happen before).
Stopping & restarting the vpn client will show back correct info ...
Rgds,
GS
PS: there is an incoherence in your message wrt client # (gui says 3 while nvram says 4)
Thanks GSpock, I had 2 VPNs up (3 and 4). Both with the empty string. I fixed the wrt# now.
Update: I confirm this is happening when WIFI service is stopped or started on my RT-AX88U Pro too.
To reproduce:
nvram set wl1_radio=1
nvram set wl0_radio=1
nvram commit
service restart_wireless
Your VPN service state string is now empty.
To fix the VPN service state string, you need to restart the relating VPN service:
service restart_vpnclient3
service restart_vpnclient4
Your VPN service state string is now showing the connection info.
Hopefully @RMerlin can take a look at it for next update?
Thanks.
