Entware Entware armv7sf-k2.6 EOS
Yes, it was mixed repos problem because I has 3 at once - entware original, maurer repo and your garycnew.
Now with entware original and your repo openssl works correctly. 💪
Great you were able to identify and resolve the openssl issue!
I have now different problem pip package requires gcc >= 9.3 but in your repo is only 8.4.0. Can you update this package ? 😉
Unfortunately, gcc is stuck at gcc_8.4.0-7_armv7-2.6.ipk with kernel 2.6, due to it not having the expanded kernel code for gcc >= 9.3.
Are you stating that python3-pip_23.3.1-1_armv7-2.6.ipk is not working with gcc 8.4 and kernel 2.6?
No pip I have installed correctly and works okay. But from pip repository package needs unfortunately updated version of gcc.
Also would be great if php opcache package can have JIT enabled ?
And imagemagick/imagick have hevc/heif support ?
Is there an older version of the python package you want to pip install that doesn't require gcc >=9.3?
As I have no time to assist with one-off packages... I would recommend downloading the garycnew Entware-armv7sf-k2.6 source and attempt to cross-compiling the packages you need against kernel 2.6 and gcc 8.4, using my Build Notes. Also... You might reach out to @SomeWhereOverTheRainBow to confirm whether they have any availability/interest to assist.
