TAILMON TAILMON v1.3.1 -Mar 1, 2026- WireGuard-based Tailscale Installer, Configurator and Monitor (Available in AMTM!)
You can try using a shorter more high quality cable. That, or finding a powered enclosure.
I'm not sure my Verbatim enclosure uses a standard cable?
A powered enclosure might indeed be a good thing if I keep experiencing problems with this one.
This has certainly had enough time to cook, and getting this out the door... huge kudos to @rangermix for his contributions!
What's new!?
v1.3.1 - (March 1, 2026)
- MINOR:
Thanks to a contribution from @rangermix, the capability of forcing the router to use IP Forwarding if it is disabled has been added. His addition will check for the existence of the /proc/sys/net/ipv4/ip_forward (and ipv6) files, and checking they are both set to "1" before enabling this functionality by adding some statements to your init-start file. So this may require a reboot before it will work completely. Apparently this has been a hang-up for several folks now, and this seems to be a working fix. For others (like me), this setting was already enabled, and this code would not interfere with that. Another interesting note is that @rangermix believes this behavior stems from routers being configured in a "repeater mode", and may have these settings turned off by default.
- PATCH: Changed the date/time to include the offset alongside the timezone. This is to give more visibility for those who aren't assigned a standard timezone name, and in some cases would fall back to using "GMT". Thanks to @Tarek Yag for reporting this, and for @EmeraldDeer providing a deep dive into the date command options.
Download link (or update directly within TAILMON/AMTM):
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/TAILMON/main/tailmon.sh" -o "/jffs/scripts/tailmon.sh" && chmod 755 "/jffs/scripts/tailmon.sh"
Significant Screenshots:
None today!
