TAILMON TAILMON v1.3.1 -Mar 1, 2026- WireGuard-based Tailscale Installer, Configurator and Monitor (Available in AMTM!)
Apparently Tailscale and/or my router went down (I can’t reach them remotely) and now TAILMON is mailing me about that EVERY minute… (so there is still some connectivity)
What does the email say? Perfect case to have email rate limiting turned on. 😉
failure:%20TAILMON%20has%20detected%20that%20the%20Tailscale%20service%20was%20dead%20and%20not%20connected.%20TAILMON.%20has%20reset%20the%20service,%20and%20reestablished%20a%20connection%20to%20your%20Tailnet.%20Please%20investigate%20if%20this%20behavior%20continues%20to%20persist.
I read about rate limiting in previous release notes, but I must have read them wrong, because I thought it got enabled in that release (by default)…
Definitely going to enable it when I get home!
Sounds like it's having trouble starting or staying running... Do you have any other devices on your network that you could remote into in order to get to an ssh prompt or UI page for the router? It's always nice to have a backup method to backdoor into your router. :)
Yeah, sorry... It's off by default... shows as a red "RL" on the operations menu.
My router is refusing all SSH connections that usually work:
  • on iPhone via Tailscale
  • on iPhone via OpenVPN
  • on a Pi on the local network provided by the router (via Tailscale or OpenVPN)
That’s a bummer. I was going to ask the same as Viktor. WireGuard on the router saved me a couple of times so I could ssh in and fix Tailscale with Viktors’ special C, I issue —reset option.
It did start me wondering whether one of those power plug devices you could operate over a phone connection to reboot it (and the ONT) might eventually be a good investment …
Shameless plug for knock.sh. If you had a reboot command set up, you could potentially send a reboot command to the router from the local network (eg. from Pi?).
knock v1.2 - router commands for non-admin users
Had the same thought. A break-glass device in case there's no other option.
Hmm not sure that one has a SIM card option though? … not much chop having a phone App if it only works over WiFi … if the router running the WiFi is not working.
The suggestion I posted above is like an independent plug run off a SIM card (ignore the WiFi capability)… you can make like ET and phone home …
Just thinking about this though, if the URL can’t get through to the network as nothing is advertising access to it (see XIII list of devices he’s tried to get through on), will it still work ?
The router could have a ssh issue only. He mentioned access to the local Pi. I would think the router would really have to be in trouble if the firewall logging is down too (what knock.sh is monitoring). Note the email function and tailmon is still working on the router. One would think knock.sh would be too.
Rung
I have doubts about that as well, but it would at least be one other thing to try.
All the things I tried have in common that they require SSH to work on the router.
I haven’t looked at knock.sh yet, but that might not depend on that?
Very true. You'd think if there's a SIM involved, there's probably an ongoing cost as well.
The other item I have on my to-do list for RTRMON is to build in some automated reboot functionality. For instance, if the Internet goes does, and still down after an hour, reboot. Maybe coming up with some other scenarios. In one of my older scripts, it would check for the existence of a file that you could place out on GitHub (or wherever) and if the keyword in this file was found, it would reboot the router. That was another break glass option in case I got locked out of getting to my router.
Correct. Knock uses firewall logging to execute pre-planned commands like reboot. No ssh needed.
I did turn that on and it looks like my router is again not accessible today, so this might be a "good test"...
Unfortunately I did not install knock.sh yet... That just got high priority on my to-do list!
It's again the SSD having issues... (I can still read some logs that syslog-ng sent to my Pi) It's super annoying that I can no longer SSH into the router when the SSD switches to read only mode (until a reboot and possibly eject the SSD drive once).
Why would that be?
And so much for being more stable with an SSD. I have had way more issues using the SSD than I ever had with a USB stick 😢
Ah, looks like reading also fails? That makes more sense...
2026-02-28T17:43:19+01:00 router kernel: sd 1:0:0:0: [sdb] tag#1 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
2026-02-28T17:43:19+01:00 router kernel: sd 1:0:0:0: [sdb] tag#1 Sense Key : Not Ready [current]
2026-02-28T17:43:19+01:00 router kernel: sd 1:0:0:0: [sdb] tag#1 Add. Sense: Logical unit is in process of becoming ready
2026-02-28T17:43:19+01:00 router kernel: sd 1:0:0:0: [sdb] tag#1 CDB: Read(10) <REDACTED>
2026-02-28T17:43:19+01:00 router kernel: print_req_error: I/O error, dev sdb, sector 264310575
2026-02-28T17:43:19+01:00 router kernel: EXT4-fs warning (device sdb1): htree_dirblock_to_tree:995: inode #8259739: lblock 0: comm sysstate: error -5 reading directory block
Just got my first TAILMON email. Next one should "wait" 1 hour...
In many cases, the enclosure matters. Even with the 'bulletproof' enclosure I've got, I've still had the occasional instance where the SSD doesn't come active until I unplug the USB, and plug it back in. The last few times after it spontaneously rebooted, or forced a reboot on its own through MerlinAU to update the FW, it's had no issues thank goodness.
You might want to reformat that SSD, or perhaps run an error checking/diskcheck tool against it... and if all else fails, try a different enclosure?
@XIII ... the problem could also lie with your USB cable to your enclosure. If it's longer and not well shielded, it could be losing power, and there's already very little power coming across that USB port to power your SSD. You can try using a shorter more high quality cable. That, or finding a powered enclosure. If I keep experiencing problems I might go with something like this:
