Entware on Ac88u
Noble
Hi
this is my first post on this forum, i just purchased an Ac88u, flashed with merlin 380.66_4 and i want to install Entware, i searched in internet for info and all guides are for earlier asus routers. i learned that for ARM devices i need to install Entware on USB compared to directly into the router for MIPS devices.
Anyone installed Entware already on ac88u? if so can i get a simple guide line on how to?
Thanks in advance
Edit: i managed to install Entware via EXT3 USB, now i am trying to figure out how to install shadowsocks client
any expert here?
If you want ad-blocking at the same time, use AB-Solution, it installs Entware for you if you use the ps option that installs pixelserv-tls to block https ads.
thanks for the reply, i have another question, entware is the same as entware-ng ?
Yes it's the latest as ARM, MIPS and x86 forks of Entware was merged into Entware-ng, so you want the ng version.
