Entware entware segmentation faults
ebalsumgo
So I have basically 3 packages installed from Entware JQ, Nginx and HTop and all of them are throwing segmentation faults after upgrading to latest merlin, any suggestions on a fix? I cannot get any useful information out of any log file I can find on the router so I am not sure what exactly is causing the problem right now :(
Are you sure you're using the right version of Entware? At a minimum, there are ARM vs MIPS versions. One architecture won't run on the other.
Yea all of it has been running just fine for 2 years, basically after upgrading to 386.3_2 all the entware pkgs are throwing segfaults
