Port Statistics on my Netgear switch (model GS724Tv3) is showing a very high number of Transmit Packet Errors, but seems to occur mostly on teamed ports. I'm a bit of a networking dunce, so overly-clear responses are helpful. My network is otherwise functioning fine, I can copy to/from ReadyNAS devices I have connected on teamed ports, but the number of Transmit Packet Errors (22,766,266 errors on one port, for example, after about 3 days of uptime, similar high numbers on the other teamed ports) is concerning.
My setup:
Router: Asus RT-N56U
Switch: Netgear GS724T Switch
NAS: Netgear ReadyNAS Pro 6 (two of these)
ReadyNAS Pro 6 Settings:
I have the two ReadyNAS's both connected in teamed/LAGS mode. Both ReadyNAS's are running the latest firmware (4.2.22).
The ReadyNAS admin tool reports a functioning connection:
• Online (Redundant) / 2Gbit / Full-Duplex, with teaming mode of IEEE 802.3ad LACP, Layer 2 xmit_hash_policy.
• Speed/Duplex: Auto-negotiation
• MTU: 9000
• Jumbo Frames Enabled
Netgear GS724Tv3 Switch Settings:
Boot Version: 5.0.3.2, Software Version: 4.2.1.9
Port Configuration:
• Port Type: Port Channel
• Port Speed: Auto
• Physical Status: 1000Mbps Full Duplex
• Link Status: Link Up
• Link Trap: Enable
• Maximum Frame Size: 9216
• Global Flow Control (IEEE 802.3x) Mode: Disable
LAG Configuration:
• LAG Type: LACP
• STP Mode: Disable
• Link Trap: Disable
• LACP Priority for all ports: 128 / Long Timeout
I'm guessing that the problem is somehow related to either the teaming/LAG/dual-Ethernet connections, or using Jumbo Frames, or both. I have the MTU on all of my devices (MacPro teamed NIC, PC NIC, Netgear Switch, two teamed ReadyNAS devices, Synology NAS teamed) all set to 9,000 MTU with Jumbo Frames enabled. Curiously, the Netgear Switch MTU must be set to the maximum listed value (9216) rather than an even 9000 like the other devices, or the network fails.
Let me know if there's something obvious/stupid in the settings above, and I'm happy to provide any other pertinent settings info or logs if helpful. I'm hoping I've just got some simple mis-set configuration somewhere that's easy to address.
Thanks for any help!
My setup:
• MTU: 9000
Port Configuration:
• Port Speed: Auto
• Link Trap: Enable
LAG Configuration:
• LAG Type: LACP
• STP Mode: Disable
