Feature Request - VPN by SSID
ninja888
I've seen that the Asus Merlin firmware can be configured to support VPN by SSID (VPN over SSID1 and non-VPN traffic over SSID2 for example) by the following guide however this is quite complicated to setup and would be much better if supported through the GUI i.e. for example by adding a "SSID" selection drop down for each of the VPN clients that, when enabled, only devices connected via that SSID would be routed through the VPN...
Is it possible to add this feature into the admin GUI to make it easier to setup?
https://github.com/RMerl/asuswrt-me...or-VPN-and-SSID-for-Regular-ISP-using-OpenVPN.
I don't currently plan on adding this feature, sorry.
