CoolDuckie
Hi all,
I am using the Merlin 374.42 FW on an AC68 router. Very happy with Merlins FWs- thanks a lot, Merlin!
I believe there is a common, very long-lasting bug in Asus' firmwares: Open, established connections are not closed by the firewall or the Parental Control feature. It works by preventing new connections. I discovered this when my youngest daughter started playing online Minecraft all the time. I tried to block access after 23:00, to ensure that her sleep isn't disrupted. However, she soon discovered that if she just kept playing on the same server, the connection did not close.
The same happens with the firewall network services filter. Perhaps the parental control uses the same code? Is this a known bug and has Asus plans to fix it? Can it be circumvented?
CD
CD
